As the saying goes, "There's more than to skin a cat." I am just saying—no offense to any cat lovers out there.True, Nylocks even better.
I would venture a guess that over 90% of the pop rivets available at hardware & big box stores are the aluminum type. The steel type are often rare and I've only seen them in the 1/8" size.
I can tell right away when using steel rivets because the squeezing force required to break the center pin is much, much greater.
Hi All, I have been meaning to stop by the forum and provide my fix to the external catches. Following the threads on this forum I installed catches using some supplied from the US - why we can't get good versions here in Aus. for less than the cost of a house is beyond me. But good old amazon to the rescue again.
After installation I developed cracks on the bike side of both panniers at the rear catch and the left one broke entirely. My analysis of the situation was because I installed the rear catches too far into the curve of the fairing and then used a hard flat backing plate on the inside of the curve. Possibly also the force of the rivets didn't help the situation either.
To fix it I first plastic welded the cracked pieces together - not a pretty first attempt at plastic welding but I was okay with it as I knew it was to be covered in the next step. Then using some carbon fibre weave I already had I applied patches to both the inside and outside of the fairing, initially following youtube fairing repair guidance of good quality CA glue to wet down the weave but then reinforcing and finishing with West Systems Epoxy with slow hardener. Once cured I then bent the backing plate to match the inside curve of the fairing and made a rubber grommet from some waste fuel hose. Finally I used nylock nuts and bolts instead of rivets this time.
Of course I used coarse sandpaper first to key the surface. The repair seems to be holding up just nice but I am yet to load of the panniers and go for a long - but I am confident that these two patches are now the strongest parts of the fairing on the bike. If the front ones crack as well I will do the same treatment and should be a bit neater and efficient with it, but so far so good they are holding.
The last photo is just for giggles to prove I do ride the bike outside of commuting to work - there is "big" everything in Aust - almost like a competition between towns to see who can have the "biggest" whether it is sheep, bananas, cows, - you get the drift...
Mark
I'd add a dab of RTV sealant to prevent seepage...I also plan to use flat head screws with with nylon lock nuts, ofcourse with some alimunium back plating.
Thanks Mikesim, Mwethers and Phil,
@mikesim, I like the low profile and compactness of the Franzen compact latch 1470. where did you buy it from, online? and have you manage to fix these, any pictures ?
Kind Regards
Peer
So, you are drilling thru both the outer pannier housing and the inner pannier wall, correct? Does that method seem secure? Does the inner pannier flex a great deal when the screws are tightened? Your method of attachment obviates the need for disassembly of the outer pannier housing or attempting to place a reinforcement washer/plate on the underside of the housing. This would make the job about a half hour vs several hours. Worth thinking about.Hi Phil,
Yes, on the fairing side (in the saddlebag) and secured with the washer and locking nut.
Reinforce all of the plastic bosses with epoxy even if they still look good.I haven't been on in quite a while, and thought I'd drop back in......
My project for this spring is to actually attempt to UNDO my exterior latches. On my bike it was the screw bosses on the black plastic inner saddlebags that failed -- the bosses that the latch mechanisms mount to. The plastic seemed brittle. Due to others' experiences, I added exterior latches. I sort of regret just jumping straight to that solution. So I have just purchased new inner saddlebag panels and am going to attempt to restore the bike back to the original latches. The side panels were ~$250 each, and the molding codes show they were made in 2016. The only thing I can't undo will be the small screw holes I drilled in the saddlebag lids for the latches. New covers are expensive, and one is no longer available from Honda. But my bike is silver, and I have some heavy-duty sparkly silver stickers from work that are a great match and will cover them up for the near term. As for the lids, I only have 1 screw boss holding one of the metal catch loops that's cracked with a small chunk missing, and I think I will be able to fix that just fine with epoxy. I will keep my eyes open for clean used lids.
Speaking of epoxy, I am thinking about adding some around the screw bosses that hold the latch mechanisms, just to reinforce things, before reassembly.
Will show pictures if all goes well. If all doesn't, I may not.![]()
