Could the TPS adjustments fool the MAP or is my previous post a solid indicator?
I believe that the TPS adjustment is hiding the problem rather than solving it.
The symptoms you describe EXACTLY fit a faulty MAP Sensor.
I know this because I HAVE BEEN THERE.
I have been down the same road as you adjusting the TPS with pretty much the same results and then replaced the MAP to solve the problem.
Remember that the TPS is a mechanical sweeper and usually will not show any symptoms at a fixed throttle position unless you stop the sweep at EXACTLY the right spot.
It almost always shows as a hesitation or flat spot as you wind on the throttle.
The MAP is a piezo crystal under vacuum (variable pressure) to produce a voltage.
In my first attempt to explain this, which got lost in the time-out, it may have been easier for you to understand.
Another consideration is that if the TPS WAS faulty, even with a "dead" spot, it would log a fault code because the voltage would drop to zero momentarily and the ECU will never accept zero volts as a signal from a TPS. It must always be between 0.3 and 5 volts.
I am 99.999% sure that the MAP Sensor is your problem BUT you MUST ensure that you set the TPS back to no more than 0.6 volts with a closed throttle (preferably 0.45-0.5 volts) or you may still have strange symptoms without a fault code.
If you look at the wiring diagram you should be able to work out how to set the voltage correctly.
If not, let me know and I will describe it to you.
The MAP Sensor is common to many Honda motorcycles but not all.
You should be able to pick up a second-hand unit for $20 or so.
PS: I am off for a ride in the country to have lunch with friends at a country pub. 300+ km in great weather with great company is too good to pass up!
