Hi Clement,
I have had MIL 8 issues for over 2 years. My story is well documented in this thread. I replaced the TPS sensor, the MAP sensor, the battery, and the voltage regulator, and even tried different gas because others have had success with one or more of those attempts in the past.
I do believe mine is fixed now and the apparent solution is also the cheapest one I’ve tried so you may consider starting there.
If you will definately install it, I will send you a connector and cable to bypass the TPS wiring in the harness. If it seems to fix your bike then I can be more sure that mine is fixed also.
Mark
(This reply was copied from http://www.nt-owners.org/forums/showthread.php?12031-Introduction)
Mark
