charlie b
ROFLMAO
Yep. We use our mobile hotspots when on the road quite a bit. It is frequently much faster than the WiFi provided at campgrounds or hotels. We have exceeded our monthly allowance a few times (and that is 10GB/mo). When you have two people on laptops/tablets it goes fast.
A hint. If you know you are going to be using it a lot, call your cell service and upgrade your data plan for that month. For us it is $10 to upgrade one level, but, it is $15 if we do not and then exceed that level. Not that much, but, one trip we exceeded the next level as well (2 week trip and we went over 20GB). Ouch! That was when we found out that streaming movies takes a TON of data
Also, your cell provider probably has an app that tracks your usage for the month (Verizon has a good one). When running a hotspot I would check it daily. Gives you an idea of which things you do use the most. Typically it is streaming video. The app should also have custom set warning levels so you can get a notification when you have gone over certain levels. I usually set mine at half, 80% and then 90%.
