I disconnected and reconnected the two wires at the lower piece on the right handle bar.
I noticed the plunger or switch (whatever that little piece is) on it was flaccid. It goes whatever direction I push it and has no spring. It also gets hot after a few minutes. And if I shake it, the rear light flickers. Not sure how it’s all supposed to behave. I think it’s part number: 35340MM5600P.
I traced the wiring from the right handle bar to the left side harnesses and didn’t see anything that jumped out at me related to the problem the brake light issue.
however, my NT700 have both and audio cable and charging port in the left fairing pocket. It looks like this under the pocket (see attached). Open to thoughts on this and possible way ahead to fix the brake light issue and the weird wiring.
