Thanks.I had the same jack that worked fine for my C10 Concours. I never figured out a way to use it with my NT. Good luck.
Amen. I made a platform using 3/4" scrap plywood cabinet door. Built it up with fixed wood blocks and high density 1/4" foam. I rigged some tiedowns to stabilize side to side, but it was still a pretty unstable setup.Borrowed my buddy's motorcycle jack that looked just like that. Despite wood blocks and spacers, it was the sketchiest and most unbalanced method I've ever used.
That's what I'm thinking. My Sabre didn't have a center stand (rusted off half of it while the PO had is sitting outside in New York). Have to re-orient my thinking. Thanks!I didn't need a lift when I had my NT. All maintenance can be handled with center stand deployed. With normal weight distribution the rear wheel will be off the ground. Get creative with heavy stuff you having laying around the garage (bags of Quick-crete, top soil whatever ) and securely strap down items to pillion. Will pop front tire off the ground.
Thanks! That would be helpful!I've been using one very similar from Harbor Freight. I just have to use a 1/2" board to help balance it so it doesn't sit on the exhaust. I do not remove the exhaust when changing rear tire so mine works great. I'll see if I have a picture of it when holding the NT. If not, next rear tire change, which may be before winter sets in, I'll get a picture. Note, I always use tie downs when lifting any of my three bikes.
Did you ever find pictures?I've been using one very similar from Harbor Freight. I just have to use a 1/2" board to help balance it so it doesn't sit on the exhaust. I do not remove the exhaust when changing rear tire so mine works great. I'll see if I have a picture of it when holding the NT. If not, next rear tire change, which may be before winter sets in, I'll get a picture. Note, I always use tie downs when lifting any of my three bikes.
One time removing the rear fender has me wanting not to that again.I don't see a need for a jack to lift both wheels at one time. I have taken front wheel, forks off by just center stand and a 8" cement block in my top box, or luggage rack area. That weight always keeps rear tire on ground, allowing front to be detached
