Auxiliary fuse block install
Southwest Ohio
2004 ST1300
For those of you that have installed an auxiliary fuse block, where did you find a "switched/key on" power source? How did you connect to it? I would prefer to not cut into any factory wiring.
Thanks,
Rich
Thanks,
Rich
Check out ThunderBox. It comes in 16A ($80) and 32 A ($90) variants. It switches on the circuit when the engine starts running smoothly and turns them off when the engine is off. No connection to ACC etc needed. You only connect it to the battery.
I used the brown wire closest to the tail light.
Made the connection with a post-tap barrel type connector
