On my GF's NT I clean the cables and kinematic with brake cleaner, dry with the air nozzle and apply some silicone spray for lubrication without attracting dirt and dust...Is there a way to grease, lube or otherwise effectively maintain the pannier latches to keep them in good working order?
Thank you MikeJon, periodic cleaning and lubrication will increase the longevity of the latching system. I use a graphite based lock lubricant as it does not attract dirt and is also good to use in the lock cylinders on the rest of the bike. Also, remember to "gently" close the pannier lids by depressing the lid in the upper center of the lid until you hear it "click" into place. Finally, periodically inspect the molded plastic bosses that the lid hasps are screwed into and look for signs of cracking. Reinforce these bosses with an epoxy such as JB Weld. Even if they don't show signs of cracking (yet) it's a good idea to reinforce the bosses before the cracking occurs (and it will). Hope this helps!
Thank youOn my GF's NT I clean the cables and kinematic with brake cleaner, dry with the air nozzle and apply some silicone spray for lubrication without attracting dirt and dust...
As Mike said I would strongly suggest reinforcing the plastic lid bosses with epoxy or similar. The plastic is brittle enough that they will likely crack. Prevent problems before they crack.
