My 2010 NT700V has developed a problem when hot, if you let the revs drop below about 3000 then the engine will quite often cut out and die, if I keep the revs above 3000 then it seems to run OK.
The MIL light does not come on when this happens.
I'm thinking the crank sensor might be failing??
