OK, I took four-five meathods to fill up an NT front tire from 15 psi to 30 psi and put them Head to head. Lets see how they do...
Slime in a can. I put one of these in my wife's old car tire and it may have gone to 5 psi. No more. The can is way huge so If you want to carry slime, carry a small bottle of it and use a pump.
Maybe on a bike tire it would fill it a bit more, but for its size, I am leaving mine at home. Maybe I had a bad can, but the real estate these take up IMHO can be better used by pumps...
Slime Tire Topoff e-pump.. $13
https://www.walmart.com/ip/Slime-Ti...46015&wl11=online&wl12=16782755&wl13=&veh=sem
A little larger than some small Slime pumps I have, it took 5.5 minutes to pump up the tire...didnt get hot, the clip leads I used to connect the battery to the cigar lighter type plug didnt get hot.
Gage jumped around at times but for $13, it worked as advertised. You can make a connector to go from the male cigar lighter to your bike's trickle charger plug but other Slime pumps come with that.
CO2 cartridges. You would need three of these to go from 15 to 30 but you better carry 9 ea. Many inexpensive "Applicators" out there for 10-20 bucks. They are fast....and expensive, at a dollar a round which gets you 5 psi...and when you are out, you are dead in the water. Still, for the weight and real estate they take up, I am carrying them as there are some in my Stop and Go plug kit anyway.
Lezyne pumps are made in Taiwan and are quality machined CNC metal. They have buttons to let air out and work on both types of bike tire valves. They dont leak. Tests in bicycle magazines really like them.
Lezyne Litedrive. $25. High pressure low volume. Max PSI 120 . Six minutes and 700+ easy pumps will get you from 15 to 30. Only nine inches long.....
Lezyne Micro floor drive HV. Low pressure high volume. Max PSI 90. $50. 12 inches long. Two minutes and 150 pumps. Floor mount with stand and T handle. When you pump this baby, you will know you are getting a workout but after two minutes nothing on your body will hurt and the long ABS hose and floor mount make , IMHO, this the pump to have if your e-pump fails.
Dollar store pump. Internal pump seal fails after a couple psi...landfill material....
