Now that I've put a few hundred miles on the PR3's, I thought I'd post a quick review.
* I, of course, can't yet speak to the wear life of the tires, but from everything I've read they will last longer than the PR2's and much longer than the OEM Bridgestones (replaced at 7000 miles).
* Handling: I now find myself zipping through tight corners at about 10 mph faster than with the OEM tires. The "feel" of the tires through the turns gives the rider great confidence. Would the Bridgestones taken me through the corners at equal speeds? Probably. But motorcycle handling is all about rider confidence, and better tires bring confidence. These are dual compound tires that really hold the corners.
* Front end wobble: With the OEM tires, even when new, if I loosened my grip on the bars greatly the front end would wobble. Slightly at first, then progressively worse until I would put light pressure back on the grips to stop the action. Now, this may not have been directly related to all OEM Bridgestones. It may have been slightly out of balance, etc. But, with the PR3's, there is no wobble at all. Straight and smooth.
*Wet weather: The PR3's are designed to thrive in wet conditions. I found the grip nearly in the wet nearly what it is on dry pavement. The weep holes on the back tire seem to be well designed to assist in wet weather. The front tire has an entirely unique tread pattern, but was equally sticky on wet roads.
*Appearance: OK, this should not matter, but it does. I like the look of the PR3's. The back tire has a cool pattern to it. I was a little worried that the front tire would produce road noise with its unique tread pattern, but it is silent and smooth--and looks cool.
As far as mounting goes, I had the dealer mount them when they did the 8k service (done at 7k). The bill for the valve adjustment (adjusted one with specs provided for each), service and tire mounting was $462. I paid $0 as I opted for the 3 year service plan from them back in January.
I'll stop here, since I promised a "quick" review...
--Enjoy the week!
Jeff
--Enjoy the week!
Jeff
