Finally got around to taking a Dremel and a file to the seat pan on the Corbin.
Used Katherine's suggestion of using putty to locate where I needed to take out seat pan material.
Scribed marks (slightly larger than Fuzeblock outside dimensions) where I needed to cut and went to using the Dremel.
Seat now fits nicely over the Fuzeblock with no interference. The cutout was not as big as I had originally envisioned and was fairly easy with the Dremel. However, even with the guide on the Dremel it was difficult to get a straight cut.
The most interference with the seat pan was on the front of the Fuzeblock. So the actual cutout is shorter front to back, than the outside dimensions of the Fuzeblock.
Now back to riding.
Pics below:
http://i1108.photobucket.com/albums/h417/tawilke46/NT700V Seat Fix/IMG_0388.jpg
http://i1108.photobucket.com/albums/h417/tawilke46/NT700V Seat Fix/IMG_0386.jpg
http://i1108.photobucket.com/albums/h417/tawilke46/NT700V Seat Fix/IMG_0384.jpg
http://i1108.photobucket.com/albums/h417/tawilke46/NT700V Seat Fix/IMG_0380.jpg
http://i1108.photobucket.com/albums/h417/tawilke46/NT700V Seat Fix/IMG_0379.jpg
Not as professional a job as I would have liked, but it works just fine. Will have to see if it affects the performance/comfort on the rear of the seat. I'm betting it won't make any difference.
Don't usually ride anyone back there anyway.
Edit: If you use a high speed tool such as a Dremel, be sure to wear breathing protection. The black seat pan material comes off as a fine powder and smells like airplane glue. So protect yourself.
Now back to riding.
Pics below:
