I am preparing to sell my Deauville, but on my last long, hot trip occasional drips of coolant trickled down the flywheel cover. I want to make it right before I sell it, so I removed the left Fairing and Discover it is leaking from The Joint collar between the cylinders. The only way I can see to replace the O-rings is to remove the engine and remove one cylinder to get the joint collar out just to get to the two bit o-rings? Is this true? Or if I remove the two clips on the joint collar, can the collar be moved fore and aft enough to replace each o-ring?
