Cleaning up Wheels
Manfred
Stuart Brogden
La Vernia, TX
2010 Honda nt700v
I used this stuff in the Army to clean my brass. It's still available. I have a can in the garage and it works GREAT on the aluminum wheels on the NT700. NEVRDULL
hmm... I'm weary on using anything abrasive on aluminum as it removes the protective oxide layer... hence they're corroding even faster...
A surprising wheel cleaner/brake dust remover: any "plastic care product" like AmorAll (which is bad for plastics anyway... makes them brittle, prone to cracks...)
But that oily stuff is really good for cleaning those wheels; just don't get it on your tires over above side effects...
NEVRDULL is not abrasive.
Think I'll give the NEVRDULL a try. At 102,000+ miles mine are looking pretty bad after miles and miles of rough weather, sand, salt, etc. Will give it a try before I install new tires in early July just before a huge trip into the Northeast. If it doesn't work, I'll use the same brake caliper paint that matches the engine and paint them while I have them off for the new tires. NEVR thought of it :rofl1: Pun intended :)
Good topic. I've found the rough casting on the spokes and hub of the NT are hard to clean. Even the pressure washer has a hard time with it. I think the NEVRDULL will work nicely on the machined parts of the wheel, but not the cast parts. Looking for recommendations.
I don't bother with the cast parts :p
