I just did a valve check and adjustment on my NT last week. I posted some observations about it because the bike sounds a little "ticky" ever since. I'm going to do it again as soon as my 10mm off-set box wrench arrives (for adjusting the front cylinder exhaust valves). In the meantime, I went through the service manual and several posts to compile a step-by-step list of the order to do things.
If I'm missing anything or have it stated incorrectly let me know and I'll revise it. Also, I couldn't find if there was a way to attach a PDF file to the forum, so I just cut & pasted my document. Hope this helps someone
Valve Check and Adjustment Checklist: Honda NT700V
** Mark wires, hoses and components removed or disconnected with a Silver Sharpie to make reinstall easier. A “match-up” line or mark on both sides of connecting parts helps w/reinstall.
Remove seat 3-6 (numbers with dashes correspond to section & page in Service Manual)
Remove fuel tank rubber 3-7
Remove mid cowl inside covers (lids) [Phillips #2] 3-11
Remove cowl pocket lids 3-12
Remove cowl pockets [Phillips #2, 5mm hex, 8mm socket] 3-12
Loosen tank pivot bolt [10mm] 4-5
Remove tank mounting bolts & collars [10mm] 4-5
Lift & secure tank- use strap or prop up to hold (Remove tank: optional 6-44)
Remove air cleaner cover [Phillips #2] 4-7
Remove air filter
Remove (2) air snorkels [Phillips #2] - plug holes
Disconnect hoses and wires from air box - snap hose out of C-clamp (L. Rear) 6-45
Remove air box base - plug holes - tape hose openings 6-45
Loosen or remove spark plugs [5/8” plug socket] (optional) 4-7
Loosen throttle body (TB) bands - front & rear cylinders [8mm deep w/ 1/4” ratchet] 6-48
Release wire harness on front side of throttle body (TB), white tape @ the spot, disconnect 2-wire clip on lower right side & tape clip to radiator hose to keep from falling out of sight
Disconnect wires and hoses so throttle body can be lifted, turned & set on left frame rail w/o disconnecting throttle cables
Secure TB & hoses/wires out of the way to side rail w/duct tape or bungee cord etc.
Remove front & rear plastic valve cover protectors 9-6
Remove hose from rear valve cover
Remove rear valve cover bolts [8mm] 9-7
Remove rear valve cover, gasket & dowel pin
Remove crankshaft & flywheel access ports on lower left side [10mm & 6mm Hex] 4-9
Set crankshaft to RT notch (follows F on flywheel) - as intake valves open, then close [17mm] 4-9
[Picture of flywheel with markings can be seen on page 12-10]
Check rockers for play to verify TDC
Check & adjust valves [10mm off-set box wrench] torque to 17 ft lbs - intake .006, exhaust .008 4-9 thru 4-11
Replace rear valve cover [8mm] and torque to 7 FT lb
Reconnect valve cover hose
Remove front throttle body insulator manifold - plug hole [10mm?]
Remove hose from front valve cover
Remove front valve cover bolts [8mm]
Remove front valve cover, gasket & dowel pin
Set crankshaft to FT notch (follows F on flywheel) - after intake valves open, then close
Check & adjust valves, [10mm off-set box wrench] torque to 17 ft lbs - intake .006, exhaust .008
Replace front valve cover [8mm] and torque to 7 FT lb
Reconnect cover hose
Replace crankshaft & flywheel access ports on lower left side [10mm & 6mm hex]
Re-tighten spark plugs if previously loosened or removed
Replace front TB insulator manifold [10mm?]
Replace front & rear plastic valve cover protectors
Install TB (lube around inside opening of insulators), connect wires & hoses
Tighten TB bands [8mm deep socket]
Replace air box base and reconnect hoses and wires
Replace both air snorkels [Phillips #2]
Replace air filter
Replace air box cover
Lower tank
Replace cowl pockets [Phillips, 5mm hex, 8mm socket]
Replace mid cowl inside covers (lids) [Phillips]
Replace tank mounting bolts & collars [10mm]
Retighten tank pivot bolt [10mm]
Replace cowl pocket lids
Replace fuel tank rubber
Replace seat
Congratulate yourself on just saving $300-$400!
Fire it up and go for a ride!
Remove air filter
Replace air filter
Lower tank
Replace seat
