After my cross country trip, my BT 023 was squared from all the 2up super slab riding in the extreme heat. I got close to 9,000 which I can live with given the situation.
I've got my tire changing routine down without removing the muffler.
1. undo rear muffler bolt and loosen the bolt near brake peddle but otherwise keep muffler in place.
2. Use my 27mm open wrench on the axle nut.
3. With muffler loose, push it up and away to get a 14 mm socket on the brake stopper bolt to loosen but finish removing with 14mm wrench. Again, push the muffler up and out to remove stopper bolt. The rest of the tire removal is the same as indicated in the manual.
Tire replacement
1. The hardest thing is getting the brake caliper over the brake rotar when putting the tire back. I made it much easier by removing a brake pad and putting it back after the wheel was back in place. Much easier.
2. Again, use 27mm open wrench to tighten axle nut.
3. push muffler up and away to get stopper bolt back in place and tighten up with 14mm open wrench.
Draw back... no torque wrench on axle nut or stopper bolt.
I'm also getting much better changing the tires. I have a 2x4 bead breaker attached to an exposed stud in my shed which works very well. I'm probably down to a half hour once the tire's off the bike.
And I brought a balancer from Harbor Freight for $39 that worked well. No more dyna beads for me right now. I put another BT 023 but am leaning towards a PR 3 next time with Rick reporting near 15,000 on his rear tire.
Tire replacement
